Discuss Back to wall toilet with side waste in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I’d like to replace the toilet in my house with a back to wall one. The plan is to build a panel on stud work to conceal the cistern and then use the existing soil pipe which goes out to the right.
All the back to wall toilets on Victoria Plum have a cross through the side waste which has confused me.
Can I not just use a flexible pan connector for this? The distance from the centre of the waste pipe to the panel is 120mm so I don’t think a 90 degree single socket will work.
Any tips here would be appreciated. Cheers!
All that means is that you can't have side exit on the W.C pan side of the wall.
It's obvious really as there isn't a hole in the side of the pan to exit the pipe, but they've probably had people comment / complain that they couldn't so have had to highlight it.
Just use suitable 90 elbow pan connector inside the box, no need for a flexi.
Nice one, thanks mate
You could use a 110mm coupling and elbow and a straight pan connector
[/QUOTE
You could do as I have here . Kop
Reply to Back to wall toilet with side waste in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the...
Hello All, Was looking for some innovative ideas from you all.😊 I’m renovating a bathroom in a flat. The soil, hot & cold water pipe runs stops me...
Hi! Totally inexperienced DIY newbie so bear with me for descriptions! Pictures hopefully help. I’m trying to remove an unused downstairs toilet...
My sister bought a new build property which has wall hung toilets, NK by Noke Porcelona The pans are all moving enough for the silicone sealant to...
I had a plumber in to replace my old pan connector as it was leaking due to the wax deteriorating. Now when this toilet clogs up (which is a...
