Discuss bahco 15mm bender and flux application in the Plumbing Jobs | The Job-board area at PlumbersForums.net
CXR100
going to take the plunge and fork out for one of these, will be cheaper in the long run than buying
guides! anyone got any good-bad things to say about it? I rarely bend 22mm unless its a offset or on a long gas run etc. also I have stared applying flux to fittings with the solder wire tip. I know I use much more flux than usual but im not the one paying for it so....... . its a bit fiddly putting it on the pipe with it tho, how do you guys do? wont get into the debate about flux on pipe or fitting or both but I do both. I did use a brush but also keep loosing them or dropping them in dust.
Bahco benders are very good only problem in my book is they don't do a 22mm set!
You should apply flux to the pipe really as when you put it in the fitting a lot gets pushed into the pipe
bacho benders are ok, the plastic guide wears out tho so take that into consideration. best option is get a record solo off ebay, i brought 2 brand new ones for around £6 and £15 each, just have to keep your eyes open
flux what you want if its not gas, just flush ya pipework. i normally use end of solder wire as well. if i need to ill finger it around the pipe.
I use a flux brush with ever flux, the blue lid closes tight over the flux brush when not using it and keeps it all together. As for benders I got a year or so ago the Bend it now pipe benders ([DLMURL="http://www.benditnow.co.uk/index.php/plumbing-machines/bhb-15-22/product/show"]BHB-15/22 (15-22mm Hand Bender)[/DLMURL]) These are very good and feel well built. Would def go with these but I managed to get mine for £50 some how :S
Reply to bahco 15mm bender and flux application in the Plumbing Jobs | The Job-board area at PlumbersForums.net
