Discuss Banging pipe when neither hot water or heating is on, please help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gavlar80
I hope someone can help, we have a banging noise at night, it does happen during the day but other noises cover it up. we here a click from the kitchen and then a banging noise which you can here on the front wall of the house. the bang is evenly spaced apart with a bang every four seconds and this starts and stops randomly .tried turning the boiler and hot water off at night but the noise still happened. the last few nights i have turned the main stopcock off under the sink and no noise, very confused please help
Water hammer caused by the rise in pressure coming into your house put a line arrestor in
or jumper in stop tap amplified by not many clips in pipework
Have you got a CWSC in loft I would start with the ball valve replacement.
Then as you say turning the stopcock off goes silent maybe replacement will be required
Good luck
thank you i will try looking at that the tank in loft and ball valve looks new. we had a meter fitted outside recently and they replaced the tap with a quarter turn valve. we not sure if this noise has developed since then or if it was happening before
Reply to Banging pipe when neither hot water or heating is on, please help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
