Discuss Banging rads in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
richardtheplumb
Hi guys just been to see a job customer is complaining about two rads making banging noise after the heating has been on for about two hrs, could this be the trv's they are twenty years old
Did you try removing the heads from the trvs to see if noise stopped?
Didn't do that but as usual no noise happened when I was there but I was told if she turned the valves the noise stopped
could it be the radiator itself? expanding in the brackets, do the brackes have the plastic inserts on? seen a lot of problems down the line without these inserts
Thanks matty that's something else I didn't think of, I will check that out when I call back on sat
QUOTE=Matty Birch;715247]no problem keep us posted on how you get on.[/QUOTE]
Thanks mate will do
Hi guys just giving an update of the banging rads. Went to the job on sat and spoke to the lady's husband who informed me that when the rads where banging the lower half of the rads were cold while the top half were scalding hot. I suggested they had the system flushed but they don't want to spend that sort of money do the saga goes on
Reply to Banging rads in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
Hello, I have a customer with a modern anthracite vertical radiator and a modern TRV and lockshield. The radiator makes a loud metallic bang from...
Hi, I turned my central heating on for the first time today this year and it started to bang and the flame inside looked a bit erratic. Upon...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your...
My radiators make a bang noise every now and then. Doesn't seem to be a particular radiator instead it will be 1 radiator and then some time later...
