Discuss Basic tools for dealing with CH in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
ringer
My work is mainly electrical, but I need to tackle a CH installation - replacing Mid pos valve this time but anticipate more work like this in future. I have only a very few tools for plumbing, can you suggest a few must-haves for CH work?
For the current job I will certainly need to part drain the CH loop and would rather have a proper tool than use a pair of pliers, so for starters, what tool do you use to release the drain cock?
u need the sparkies forum, most plumbers dont do electrical work for obvious reasons,..................
adjustable spanner , grips , hose , bungee cable for tying up ballvalve , radiator key , a wet and dry hoover are very handy if your expanding your budget that much
FYI - Which ever adj spanner is to hand, but my preference is a 4" Bahco.
I'm not knocking you, but this is a pretty basic question. It's a bit like a plumber asking a sparks how to take a plug top off!, are you sure working on CH system is the right thing to do?
You may be able to change 3 port valves and other c/h components but can you deal with the black art of heating wiring? most sparks struggle with it!:D:D:D
I'm not knocking you, but this is a pretty basic question...
Dislike using pliers/adjustables if there is a proper tool available. Have searched for a dedicated tool but without luck.
actually, yes, I believe I do understand heating wiring. Is an area I hope to be able to specialise in as I understand that some plumbers and most electricians seem to struggle with it.
Do what most electricians do when there is work to be done.........
sub it out :eek::eek::p
imho
You could get a set of open ended spanners for each size nut you may come across, but do as the rest of us do. Adjustable spanners and pump pliers.
Eco
I have actually blown the minds of some very good sparks with some of my systems. Some are still unable to take solid food or breath without the aid of an iron lung!
Dedicated tool might help if you have good access but what use is it if the drain cock fails and you need to drain via a rad?
Ive not seen a tool like you mention but maybe the sheds? For me hunting around through my box for it when ive an adjustable in my hand already makes no sence.... and its something else to lose or leave behind :eek:
Reply to Basic tools for dealing with CH in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
  • Locked
We had a new CH system recently installed, by contractor, as part of general refurb. The Vaillant EcoTec 630 boiler was installed by a Gas Safe...
4K
nervous123
N
H
13K
R
C
  • Locked
Hi
Hi All Just signed up this morning, I have been looking at the posts for a while and thought I might aswell join! Not sure if this is the right...
2K
moore
M
  • Locked
hello all, i am a 22 year old male who was made redundant just after christmas from my mechanical engineering apprenticeship. It was a NVQ4...
1K
pmac10
  • Locked
Hi! First post - so please be tolerant if I'm raising an issue that's been covered before. My daughter has moved into an old mid-terraced...
2K
moony
M
