Discuss Baxi DuoTec fault codes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Lambed84
Anyone know what the fault code e166 relates to on the above boiler?
Thanx in advance gents
Definately E166 cannot find anything about it,what exact model Duo-etc is it?
Just looked on baxi works no e166 but i would think it a pcb problem . cheers kop
Doesn't mean anything just a glitch turn off main power to boiler leave for 5 min then switch back on was told it clears something on PCB.
Had a pump fitted Friday by another engineer. Turned boiler off at spur. Left for a few minutes, turned on and e168 appeared. Reset and ran fine for an hour. My guess is water ingress at pcb.
Cheers lads
Reply to Baxi DuoTec fault codes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
