Discuss Bending 22mm pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
learnplum
Hi, do most use a hand held device, or a spring, if you are a samson, or a free standing device, like the hilmor one?
Thanks.:tounge_smile:
For my work I use handheld hilmor, by the time you've carried your toolbox, crimper, pipe etc.....I ain't carrying a floor standing bender aswell.
Hand held. Get free standing one if you need to bend 28 or 35mm copper pipe.
Thanks guys, can you get a hand held accurate bend?
Or is the free standing floor hilmor more accurate?
What do you call accurate? +-2mm?
It’s up to you to make it accurate.
bend it and cut it to size, whats left goes to the scrapman!! - for a fee of course
Hand held! Good for upper body muscle building!
If you are a bit devoid of muscles it can be hard to bend 22mm in a hand bender though.
Reply to Bending 22mm pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Sonya K
