Discuss Bleeding a radiator for the first time in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I am trying to bleed this radiator. Can you please post which key I need to bleed? Or hat tool do I need ? Thank you.
Top right and you need a bleed key
If you have a combi boiler or sealed system you may have to top the pressure back up , if you have ,
find out how to before you bleed the rad .
One of the bleed keys as shown further up the thread
Look at the simple bleed keys at the top of this thread. Plenty of space to fit one of them in. Quote for what? A bleed key?
The size of that air tap key I posted is only 1 1/2" wide.
If you can get a screw driver in the slot, use that.
You only need to crack it open though, don't be tempted to pull it all the way out.
Reply to Bleeding a radiator for the first time in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Show us your fanciest radiators you've installed! We would love to see them! I love this Milano vertical radiator in the kitchen space. What do you think?
Hi all I need to run this CH pipework to a radiator located beyond the electric wiring in the image below. Just to be safe I was wondering if there are any rules / distances, etc I need to be following when avoiding the wiring? Many thanks. P
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
