Discuss Bleeding air from Central Heating System in the Central Heating Forum area at PlumbersForums.net
Boiler is making a gurgling sound and keeps short cycling. I believe there is air in the the system and I've already bled all the radiators. This is the pipe leading into the water cylinder, is it where I should be bleeding the air from?
Not seen the video, but that guy's an idiot. It may be totally wrong.
Sure the boiler isn't just kettling?
I'm not sure, the boiler will fire up and stay on for a minute or 2 then stop with the burner light flashing. Then after a few minutes it will start again, this repeats indefinitely. Throughout all this there is a gurgling sound, the problem seems to be exactly as described in the video I posted.
Reply to Bleeding air from Central Heating System in the Central Heating Forum area at PlumbersForums.net
