Discuss Bleeding air from Central Heating System in the Central Heating Forum area at PlumbersForums.net
Boiler is making a gurgling sound and keeps short cycling. I believe there is air in the the system and I've already bled all the radiators. This is the pipe leading into the water cylinder, is it where I should be bleeding the air from?
Not seen the video, but that guy's an idiot. It may be totally wrong.
Sure the boiler isn't just kettling?
I'm not sure, the boiler will fire up and stay on for a minute or 2 then stop with the burner light flashing. Then after a few minutes it will start again, this repeats indefinitely. Throughout all this there is a gurgling sound, the problem seems to be exactly as described in the video I posted.
Reply to Bleeding air from Central Heating System in the Central Heating Forum area at PlumbersForums.net
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed...
When I turn on our CH there's a lot of noise from one specific part of the system - the pipes on the landing, and one radiator. It sounds like...
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or...
My daughter's place has a small water leak on a ground floor radiator valve. The radiator pipework is small diameter.i.e 8 or 10 mm. A plumber...
losing pressure
L
