Discuss Bleeding Radiators in the Central Heating Forum area at PlumbersForums.net
Hi all,
Maybe a silly question here, but is bleeding radiators, one in particular! Every 3 Months roughly.
Is this normal on a combi boiler? or should I be concerned?
Thanks in advance everyone 😊
Is it air or hydrogen? Once a system, beit sealed or open vented is filled and initially bled there should be no build-up of gases. Every three months suggests there's a problem somewhere.
Whats the best way of finding out if its air or hydrogen?
I've just bled the radiators so probably wont need bleeding for 3 months or so!
Replace Boiler & offending radiator.
If the problem persists after boiler and radiator replacement, it's a normal problem.
Personally, I would persist with the problems of bleeding the radiators until the boiler stops working for good.
I do... and have been waiting for my boiler to give up and die for more than 10 years.
If it was hydrogen it would pop if you put a lit match to it. The next time you vent the radiator vent it into an upturned cup and put a match to it. Don't catch too much of a sample and be careful if you do try that. Hydrogen is odourless, however hydrogen sulphide produces a rotten egg smell. Hydrogen sulphide is caused by a bacterial problem.
Reply to Bleeding Radiators in the Central Heating Forum area at PlumbersForums.net
PSxxxxxx
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
