Discuss Brand new salamander pump leaking out of box. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
New pump fitted, this afternoon. No issues, showers, ran multiple times. Airing cupboard checked minutes before leaving property.
Left job about 1730 and get a text from customer to say the pump was leaking while her son was in the shower.
I've raced straight back, thinking perhaps I didn't nip one of the flexis up tight enough but no water was seeping out of one of the casing bolts on the side and it looked like it was leaking from another area on the casing.
It's salamander ct 55+. Not top of the range I know but is there anything that could cause this or is it just bad luck?
I too stopped fitting when the quality plummeted a few years ago. I suspect greedy accountants with zero regard for how it leaves installers/users...
I've had trouble with all the cheaper pumps from most manufacturers. Never had a salamander leak out the box but have had them not work at all. Had a couple Stuart Turners leak from the body and same with altech (grundfos made). But then never had an issue with the more expensive models.
Won't touch Salamander after one leaked out the box. Was fine on installation and when I left. 24 hours later water was through the ceiling. Leaking from pump body. Wouldn't touch their **** with somebody else's.
Reply to Brand new salamander pump leaking out of box. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar...
B
Hi I have a monobloc mixer tap which is 18mths old. a leak appeared underneath in the cupboard which looked to be coming from the flexi tail M8...
Hi there, We have a standard gravitational system at home and a Salamander pump CT force 30pt is part of the hot water system for the 2nd floor...
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
Hi, new to this forum. I hope someone experienced out there can help me find the fix. We recently finished a building project and had a major...
2K
