Discuss broken air vent in rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
beano
Hi all. Just new to this site
Was wondering is there any way of fixing a broken air vent in a radiator . can you buy a kit or anything? The vent is quite small at the back of the radiator. thanks
New radiator.
By the time you take the radiator out, drill it out, manage to get the last of the bleed vent and try to clean the threads up only to realise the spare gets stuck or doesnt fit.
youve wasted a load of time and money.
better to get a nice sniney new one and fit it
Best option is dont bother - unless your really unlucky the air in this rad will get pumped around to another radiator which you can vent Centralheatking :96:
Use to drill and re-tap rad vents on myson rads to save money when I use to work for BGas ... ones on the side. However I totally agree with above... Not worth the effort unless you're skint!! :)
Funnily enough, I've got one of these booked in for Wednesday.
Rad off, lay it flat, sharp tap with centre punch, 3mm hole and an easy-out. Job's a good 'un...
and good luck from me
Reply to broken air vent in rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
My son has an apprenticeship interview for to become a plumber and heating engineer. The have said there will be a multiple choice exam for this...
Hi all Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
