Discuss broken screw holding pan to floor in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
hi one of the screws holding my toilet pan to the floor has broken when trying to remove it , there is only about half an inch showing , i have tried using pliers and pulling it while trying to turn it anticlockwise but no joy , the floor is tiled , appreciate any help/advice . thanks .
Mole grips will probably work 95% of the time or cut it flush to the floor with an angle grinder and try and drill a hole next to it. Or leave it and stick the pan down with silicone without fixings
In order of my success rate:
  1. Small hand-vise clamp May help to file a slight flat on one side of the screw.
  2. Locking pliers (Mole grips).
  3. Broken-screw extractor. Like a tap (workshop not water!) with a left hand thread.
All require luck.
Use stainless steel screws to secure the replacement pan.
thanks for the reply , mole grips never worked , its such a thin short piece of screw they could not get a grip , ive left it soaking in wd 40 , dont know if that will help then give it another go with the pliers , i will have a think about the angle grinder or silicone options ta .
All require luck.
there is so little left of the screw in length or thickness , will look into the vice and extractor options ta .
Reply to broken screw holding pan to floor in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
my toilet pan sits on tiles , while trying to move my pan one of the screws snapped , i now have a very tiny piece of screw above floor level and...
Hi there I fitted a Sanicompact 43 about10 years ago. A few years ago i noticed that it would intermittently activate in the middle of the...
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind...
M
Hi all Moved in to a new house a few months ago. The previous owner had installed an accessible wetroom with nonslip flooring, handrails, etc...
Hi Just had a new bathroom installed with a toilet bowl that reaches the back wall. Its has a bottom entry cold feed to the cistern. The fitter...
