Discuss Can a gas boiler flu run externally from ground to second floor? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
does anyone know of a system that will allow a gas boiler (any) with a flu length to reach the ridge line (second story from ground) on the outside of the house, so about 7 or 8m? The boiler can be mounted on the external wall so there is only one bend.
We have an annoying neighbour and so cannot vent onto his land but cannot find a flu system that will allow this?
Intergas do as above or a normal concentric vertical flue up to 10m but you must factor in the fittings a 45 degree bend is equal to 0.5m of a meter and a 90 degree bend is equal to 1m of flue each section must have a bracket adjacent to the joint be accessible for inspection in case of leakage in the years to come and to examine it for its integrity . Kop
Reply to Can a gas boiler flu run externally from ground to second floor? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
