Discuss Can anyone identify this radiator please. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Keeno
I have changed TRV inserts but cant bleed the air from the system as the bleed valves are stuck shut. I have tried brass keys which present a round shape with square corners but seem too big, and aluminium keys which are more square but they break. I also tried a circular cutting tool to make a slot for a screwdriver but still wont budge. If I can find the make of rad, that may help. Many thanks. Keeno
Theres a few manufacturers that make rads like that, Its still a standard bleed nipple whoever makes it, TBH they are garbage, sorry but it may be less bother to fit another one .
myson round top age about 10-15 years old
its more likely an older barlow (quinn). Mysons were normally on the end untill the little hex/nipple carp was introduced.
if you want to keep the rad you could try and fit an easibleed
weren't the barlows the ones with double connections eg top and bottom ? (bit before my time :D )
Try BES item 7499 [DLMURL]https://www.bes.co.uk/product/115a~PL~2099~-RADIATOR-KEYS-AND-ALLEN-KEY.html[/DLMURL]
easibleed... now that is genius! Thanks. I'll try it. (what could possibly go wrong? !!! )
I sent the pictures to Quinn / Barlow and Mysons. They all say no, not ours...
I have now managed to bleed 6 out of 7 rads with a broken aluminium key plus vice-grips. The only real issue is the one I attacked with the circlular cutter blade, so may just replace that rad soon. House is warm. Thanks to everyone who has offered help here. Great forum!
if you can try and get the rad warm you might have better luck
For rounded off bleed nipples I use a brass key that ive cut the first couple of mm off with a junior, as you say the brass keys have a chamfer on them so will sometimes slip on a rounded off bleed nip.
Reply to Can anyone identify this radiator please. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I seem to have lost a bleed nipple from one of my rads somehow. It’s a double rad, one side of the rad has a nipple, the other is gone and I...
Hi Can anyone identify the make and model of these taps please? We have one dripping bathroom sink tap but the plumber we had couldn't find a way...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
C
Hello all, Like most people, I've gone to turn on my central heating after 6 months of it being off and, surprise surprise, it doesn't work. I'm...
My kitchen radiator is filling with hot water despite my TRV being set to 0. It's blazing at maximum. This goes for the rad when I try two...
2K
