Discuss Can I place a cross T fitting for a gas line? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Can I install cross t fitting ( 4 way)
close to gas meter at the “line to the house” before it enters to the house
You will have to upsize as there’s going to be extra load on the meter
Reply to Can I place a cross T fitting for a gas line? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a...
I saw on a plumerparts posts comments that the gas engineer always used an inline filter on the gas line to the boiler due to debris. I’ve just...
R
I just had installed a Navien NPE-2 with built in recirculator pump. I have a dedicated return line. The check valve for the recirc is built into...
Rogelio
R
Hi sorry im a newbie, pls help if u can. I had a new bathroom installed about a yr ago and since then when i flush the toilet the room stinks of...
