Discuss Can I Swage Gas Pipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The hand held expanders are terrible things. They split the side wall of the pipe immediately. They are too aggressive.
You have to anneal the copper first before using them.
If you use coiled copper and cut the tube with pipe cutters, you have to remove the burr completely.
We used to use them all the time - not so much anymore due to pressfit fittings.
Saying that we did a 65mm gas main recently and decided to solder the joints due to cost of fittings.
We even pulled out the branch pullers for tees and the expanders for swaging.
72C2BEF0-5A08-4AA4-A23A-344B9EA98F75.jpeg Still buy them
Reply to Can I Swage Gas Pipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
Hello, I've got a testo 327-1 that I purchased back in 2019 when I went self employed. The analyser hasn't been calibrated since purchase. After...
