Discuss Cannot remove handle Assembly on a Bristan Rio in the USA area at PlumbersForums.net
I have a Bristan Easyfit Rio Basin tap assembly, and I have a drip which more than likely means that the ceramic valve needs cleaning or replacing, however after removing the screw in the top of the handle I cannot get the handle assembly off, I'm using WD40 and tapping it gently with a small hammer but to no avail, any ideas??
  • spares-drawing.pdf
If you isolate both supplies, this tap will lift off very easy. Loosen both the grub screws at the base of the tap and lift off, tip upside down and gently tap the head off. Sorted. Refit. make sure you tighten the grub screws. Job done.
Reply to Cannot remove handle Assembly on a Bristan Rio in the USA area at PlumbersForums.net
I have a quarter - turn Cold Water Kitchen Sink Tap that has a started dripping and i am trying to gain access to the washer/valve assembly and...
R
I have a quarter turn cold water kitchen tap that has a slight drip and cannot see if the valve assembly is removed from the top? ---- there is a...
J
Hi looking for some advice. My inlaws have an insinkerator boiling and cold tap (model number HC3300 c). It was leaking from the handle so...
3K
I have recently brought new mondella pin lever 1/4 turn ceramic taps - Mondella Black Resonance Pin Lever Wall Top Assembly -...
3K
Hi, I am trying to replace the washers in a 1960's bathroom that has BBC (Barking Brassware Company) basin and matching bath taps fitted. Having...
3K
