Discuss Capping buried radiator pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
JWO
Hi, I have removed am old radiator and need to permanently cap the pipes. It's on the ground floor and the pipes are buried in concrete. I have dug out to find a straight bit pipe, intending to fit a stop end cap, but came across an old compression elbow, so wondered if I could simply use a blanking disk. Would a blanking disc be a reliable, permanent solution, considering that it is going to be re-buried, hopefully forever? Or would a stop end cap be better?
many thank
Take the compression out and put a soldered cap end if you can
Hi Jwo
The blanking disc's can be a little problematic so why not expose a bit more & remove elbow leaving the nut & olive on the pipe then fit a stop end with a bit of tape or paste around the olive.
Cover the copper & brass over with some PVC tape or similar so the cement does not touch it, should last a life time.
Thanks for the quick responses. Can't really solder as can't easily empty the pipes, so will do as Chris suggests. Cheers.
Reply to Capping buried radiator pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up...
I've had a burst pipe under bathroom floor. Ive had it dug up and made safe with the affected pipe cut and end caps fitted. The pipes are cover...
Afternoon all, I have just removed a bathroom radiator and now wondering how to plug the end? Am I right in understanding that I should screw a...
1K
A
Hi All, I have two sets of radiator pipes that need removing. Although neither set of pipes have radiators on them anymore they are both still...
Adam Rifat
A
Hi all. The current towel rail is 1000mm x 600mm and ideally I'd like the pipes coming straight from the ground into the rail. The distance...
