Discuss cast iron toilet waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
joss
Hi
I have a 4 1/4" dia cast iron waste. Anyone know what the wall thickness of this is likely to be? I intend to cut through this when I install a new toilet. Is a standard 110mm pan connector likely to fit. If not are other sizes readily available as I dont want to left without a pot to pee in
Yeah it will fit, just spit on the outlet when you push your pan connector on ;)
you will be fine with a normal soil fitting as koogatubac said
use a dribble of fairy and smuge it round with your finger first:yes:
Reply to cast iron toilet waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
