Discuss ceramic sink? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Theres a fellow on here advertises his wares, some thig like "365 drill"
Good luck
Hi Billybongo
just to let all know the reason why I start with an 8mm hole is because I once gave a sink a severe clout to get it started and the enamel went where I didnt want it to, I also leave the 18lb sledgehammer in the unguided missile so I dont get too excited.:D
regards
Mike
PS
for those of you who still have the old rawl plug mason master heres another use for it, go on you dont need a special drill, just clout it.;)
Hi Mike, the reason i used 8mm was because it seemed the safest choice the first time round and also aloud for the file to go through , and the main reason was the sink was somewhere around ÂŁ300 ,like playing with a bomb i thought , cheers mark:)
thanks for all of your great advice, ill let you know the out come when i eventually get round to doing it.
Id check out 365 Drills sounds like it could do just that job.
[DLMURL="http://www.ukplumbersforums.co.uk/redirector.php?url=http%3A%2F%2Fwww.*********.com%2F"]Tile drills bits porcelain wall 365 drills diamond holesaws[/DLMURL]
[video=youtube;PpZVa5I0blA]http://www.youtube.com/watch?v=PpZVa5I0blA[/video]
http://*********.com/jpgs/hole3.jpg
The diamond core tile drills at 365-Drills are perfect to cut into sinks, ceramic sinks, toilets, waste pans,
You can open up a 30mm hole (normal tap) to a 35mm hole (mixer tap)
Add LED lights
Add after market pure water taps
New holes or existing holes. Makes no odds
http://*********.com/jpgs/hole4.jpg
Perfect holes drilled into ceramic sinks etc with PORSADRILL from 365-drills
[video=youtube;WSMig1vWc8g]http://www.youtube.com/watch?v=WSMig1vWc8g&feature=player_embedded[/video]
Amazing display Richard will see if I can persuade someone to put on their Christmas list for Me ....oh and when are the steel toe capped socks being released?...regards turnpin:rofl:
i've acquired a small cold chisel just for this purpose although the first time i did it was really nerve-racking to say the least lol
Reply to ceramic sink? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Here they are! Totally refreshed for this year. We have given a makeover to all of the BOXSET range. All options are now presented in smart...
2K
365drills
  • Locked
Welcome to ********* and one of our projects which deals with drilling holes into ceramic sinks (Kitchens) or ceramic basins (Bathrooms). If you...
4K
365drills
  • Locked
Above is our final location and you can see a typical contemporary basin holder for a bathroom. Ready to accept the basin...
4K
365drills
  • Locked
After four hours of driving from London we reached Preston. And Installed the PORSADRILL diamond core tile drilling system for very hard...
2K
365drills
  • Locked
Now available online from Tile Depot. The Bathroom Fitters Kit from ********* Click Here to see the page PORSADRILL BATHROOM FITTERS KIT...
3K
365drills
