Discuss Clipping Pipes running though metal web joists in the Central Heating Forum area at PlumbersForums.net
Hi Guys.
This is a question on how to clip central heating pipes (Hep2 15, 22 and 28mm) when running 90 dgrees to metal web joists.
How to do it and look good. I could use a load of Britclips with a section of wood accross, clip to that.
Or use the electricals trays, and clip to that.
However the pipe must be clipped as per specification as the T&G boards are glued and screwed once down.
Running with the joist I have used Britclips, a great suggestion and the result looks real good.
Im open to suggestions.
Thanks in advance.
Donkey Table
I use these with the Britclips. However how would I support these with pipe running at 90 degrees to the run of the joists? The joists are at 600 centres. Ill get a photo tomorrow to descibe my query.
Ah I get it, a bank of them screwed to the underside of the joist top section. Doh, target fixation. I have a right angle drill so no probs.
I cut some roofing batten fix my clips to it then screw into the the bottom timber. The reason I do the bottom as it gives my room to allow everything to vent without high spotting
When running in the direction of the joists I’ll cut a piece of timber the depth of the joists and fix it vertically and then fix my clips to that
Reply to Clipping Pipes running though metal web joists in the Central Heating Forum area at PlumbersForums.net
