Discuss coal wrap round 2 pipe boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dom_plumber_ire
ive just had a fone call from a client asking me to move a coal wrap round boiler. i havent looked at it yet, but he wants me to move it back 2 inches so he can get a new fireplace in. He said on the fone theres a 5 inch gap at the back. should it not have been filled in in the first place? is it possible to do if i push it back and repipe it? what problems could arise? any comments would be well appreciated....
They were usually back filled with Rockwool to allow for expansion, possible problem is the age and use the boiler has endured, basically it could leak when you move it.
Also moving it back moves the throat which is an important contributor to the flue draught and you are moving the heat source (grate) back which can effect the heat output to the room.
Allow for two days (3 if you like after you look at it) there can be a lot of making good to the side(s) of the chimney breast.
Personally I would give a written quote with "Under Clients Instruction" in bold print as second hand is never a good idea where boilers are concerned.
Reply to coal wrap round 2 pipe boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
1K
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
Hi! I've been chasing the smell under our stairs/cellar for so long and have had many things fixed one by one, the smell still remains, next...
3K
Jeff the lonesome
J
Hi all. Okay. Long storey but, I'll try & keep it as short as possible. We are buying a house that is in a little rural village so no gas. A guy...
3K
Hi, I'm coming to the brainy forum for a proper answer! Scene - vented system, was originally gravity with Aga, then oil boiler with integral...
2K
