Discuss Cold feed mega blocked in the USA area at PlumbersForums.net
Steve weightman
Any suggestions on unblocking this cold feed without taking the tank out and removing the shelf . I've got a bottle of cleaner in and tried mains water on it but no joy. I can get about half way down the back of the cylinder .the red dots are cold feed and tee.
If you’ve tried mains there’s no hope sorry to say repipe time
Even tried this at 6 bar
[automerge]1577124297[/automerge]
Yeah I don't see an issue.
You'll never unblock the feed without repiping. I'm guessing you've backfilled the system and you've got no issues with circulation?
Yeah backfilled the tee is clear apart from where the cold feed enters. Any recommendations where on the vent to combine it. Cheers
Yeah backfilled the tee is clear apart from where the cold feed enters. Any recommendations where on the vent to combine it. Cheers we
I'd combine it in the loft, tee off as low as you can in 15mm to feed on tank.
Much appreciated thanks
Reply to Cold feed mega blocked in the USA area at PlumbersForums.net
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Hi everyone, Recently all the water tanks in the attic were disconnected to connect to the mains water supply (mine was already on mains but the...
1K
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A...
Hello, I am renovating a small bathroom in an apartment on the 5th floor. Heating is electric, no gas or oil. I have four (related) questions...
