Discuss Cold whether and shower pumps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
srmans
I have noticed recently that the pumps to my showers have to work harder in this cold weather. I expect the cold supply from tank in loft is ~2 degrees and the hot water is at ~62 degrees. It seems the hot pressure drops over the course of a 4 minute shower.
The pressure on the hot supply of the pump is the same as the cold at about 0.3bar which I understand is approx 3m head which matches the pump/tank locations. I was wondering if increasing the down pipe to the hot water cylinder from 22mm to 28mm would help alleviate the pressure drop felt at the end of the shower?
Perhaps it is just aeration, any ideas?
an increase in pipe size could give improved flow, but will not affect pressure,
that is determined by the head of water and the pump wattage.
how is the hot draw off connected to the cylinder?
is the cold tank sufficient size ( 50 gallon/200 lt )
The hot is drawn off through a Surrey flange and the cold tank is 50 gallons in size. I've installed all the pipe work myself so I'm satisfied there are no installation mistakes.
Perhaps it is just my imagination but I see it by running the mixer on full hot at the start and it shows the initial flow and then at the end of the 4 minutes, again on full hot the flow is reduced.
Reply to Cold whether and shower pumps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
Pumps and low pressure I moved the bathroom to the back the house (next room) upstairs. I put in two pumps because low pressure water area. One...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
