Discuss Concealed connection - tape or thread sealant in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Alex200274
    Alex200274 New Member
    Hi
    I have a Grohe concealed shower valve I’m in installing and the casing it has 1/2 inch BSP-P female threads built into the box. Therefore I need to attach 1/2 inch BSP male to 15mm fittings to allow me to connect up the pipes.
    As I will be tiling over I wanted to ensure the best libg term water tight connection between the female to male threads - is PTFE tape ok on its own or should I use some sort of thread sealant instead - if so any advice on product. When googling I have seen quite a few US forums suggesting you need to use both, think that’s what has thrown me.
    I have currently used tape but wanted to double check before proceeding
    Any thoughts?
    Alex
  2. steadyon
    steadyon Active Member
    Not sure I completely understand what connections you are trying to make, but if you are trying to seal on threads I'd use Loctite 55 only. Rough the male threads up very slightly with a file, wrap the Loctite 55 cord round in the right direction (clockwise looking at the end of the thread onto which the female fitting will screw) and tighten up. Use enough cord to give a tight fit. I'd suggest starting with about 10 wraps. You wrap it around and across the peaks of the threads.
    • Agree Agree x 1
  3. ShaunCorbs
    As above loctite 55 or 577
    Test before you fill in tho / tile
    • Agree Agree x 1
  4. Chalked
    Chalked Plumber GSR
    Whatever you use, pressure test before tiling.
    • Agree Agree x 1
    • Winner Winner x 1
Loading...
Similar Threads - Concealed connection tape Forum Date
Concealed Cistern - help with changing flush valve Plumbing Forum Friday at 10:20 PM
Concealed shower valve Bathrooms, Showers and Wetrooms May 30, 2018
