- Messages
- 15
Photos show light grey soil stack, it is straight run of probably 5' & goes behind fitted cupboards & shower wall to the down pipe (can't see or access that), with the slightly wider end & a rubber seal inside.
Darker grey section is the plain ended pipe piece that we've just put in to get a better seal.
The white bit is the concertina connection. That definitely isn't leaking at the joint. For sure it's 'weeping' where the light & dark grey pipes join, assume the rubber seal in the soil stack end isn't sealing efficiently?
