Discuss Condense pipe is leaking under the boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all
I have a newly fitted heat only boiler that is leaking at the point where the condense pipe enters the rubber fitting under the boiler. The siphon is not blocked and runs freely.
Any ideas?
It was only installed yesterday. My initial thought is a partial blockage in the condense pipe. Is that possible? Maybe water is backing up as the leek only happens when the heating kicks in on the initial fire up then stops. I had the thing running for over an hour yesterday with no problems whilst commissioning.
Solved!
As I suspected. Cut the condense pipe under the sink, outcomes the backed up water and what looks like grit, not my doing as always plug to stop that happening.
Drain clearing spring down the condense towards the kitchen sink waste and hey presto!
Solved!
alu oxide? was the last boiler and alu heat exchanger ?
Reply to Condense pipe is leaking under the boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
I have done pressure test for 2" high pressure pipe line by closing the pipe with rubber plugs at the ends. It was 3 bar and I kept it for 24...
