Discuss Condense pipe is leaking under the boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all
I have a newly fitted heat only boiler that is leaking at the point where the condense pipe enters the rubber fitting under the boiler. The siphon is not blocked and runs freely.
Any ideas?
It was only installed yesterday. My initial thought is a partial blockage in the condense pipe. Is that possible? Maybe water is backing up as the leek only happens when the heating kicks in on the initial fire up then stops. I had the thing running for over an hour yesterday with no problems whilst commissioning.
Solved!
As I suspected. Cut the condense pipe under the sink, outcomes the backed up water and what looks like grit, not my doing as always plug to stop that happening.
Drain clearing spring down the condense towards the kitchen sink waste and hey presto!
Solved!
alu oxide? was the last boiler and alu heat exchanger ?
Reply to Condense pipe is leaking under the boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone I hope you can help. We were getting some work done and our builder attached the boiler condensate pipe to the sink waste pipe. This...
Hello I have a condensate pipe that appears to be leaking at the joint. How do I fix the leak? Would something like plumbers putty around the...
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and...
Hi, i hope somebody can help me, i seem to have a leak from my GreeStar 30si boiler, it looks like it coming from the Siphon container, from the...
