Discuss Connector for tap with threaded tails. And should I seal the washer? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi
I'm going to be fitting a tap like this one:
And just wanted to check that this is the correct part for connecting to 15mm copper pipe using compression:
https://www.NoLinkingToThis/p/flomasta-compression-straight-tap-connector-15mm-x-1-2-/58294
If not, please could someone let me know what the correct part would be?
Also, are the rubber mounting washers that come with the tap enough to make a good seal to the worktop? Or is it usual to add a little silicone as well?
Many thanks
Yes correct if you want compression you could also use a flex if you want eg
https://www.NoLinkingToThis/p/flexible-tap-connector-15mm-x-1-2-x-300mm/6768g
And the washer are fine to the sink top aslong as you tighten the retaining nuts
I was just thinking....
I should have plenty of space behind the sink to use a normal spanner. But I was going to get a basin wrench just in case (the old school crows feet type). Would I need a 15mm/22mm one, or a 1/2"/3/4" one? I always get confused with that, especially when one end of the connector is 15mm and the other 1/2"!!
Many thanks
Many thanks
I would definitely recommend using the flexible tap connectors, makes the job so much easier.
As for the basin wrench, something like this would be a lot easier.
Reply to Connector for tap with threaded tails. And should I seal the washer? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Purchased a Grohe Basin Tap with has 3/8" flexi tails., but i notice the flexi's have no internal washer. I have purchased 2 Compression 15mm x...
2K
C
I am trying to seal a tap (wall mount faucet for a lavatory/bathroom) my wife purchased from Morocco. We live in the US, and everything is NPT...
I have purchased two Bristan Renaissance basin taps containing one black rubber washer each. The Bristan instructions say to put the rubber washer...
5K
Hi All, I'm learning loads of new stuff by reading threads on this excellent forum (old dog too!)... but last night I was reading on here about...
4K
Hi All I need to replace a leaking tap (separate, not a monobloc). I notice screw fix do 3 sizes, 8mm, 9mm and 10.5mm, is this just the diameter...
3K
