Discuss converting from open vent to sealed primary in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
red
Hello folks,
converting open vent system to sealed heating system (hot water to remain vented) - the boiler is fine to convert (glowworm ultimate), as is cylinder. I know it needs expansion vessel, safety valve, gauge, filling loop etc. Initial query: can the safety valve go in the airing cupboard (with 'vent' to outside) with the expansion vessel? - all the kits seem to have the gubbins attaching to the vessel, but rules appear to imply that it should have safety valve coming off flow pipe from boiler... Also does it need a tundish off the safety release pipe?
thanks in anticipation
no need for a tundish.
fit a separate pressure gauge in airing cupboard, or fit exp vessel and gauge combo in airing cupboard.
pressure valve can go in airing cupboard if you like. should be on an outside wall and terminate through the wall with an elbow and a tail with a kick on it
many thanks for taking the time to reply...
So basically all the components can go in the airing cupboard away from the boiler..? (cupboard has outside wall)
Or an elbow and street, or mushroom cowl.
Reply to converting from open vent to sealed primary in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
