Discuss Cool hot water in the USA area at PlumbersForums.net
Deleted member 118045
My boiler is situated in a cold roof of a bungalow. The hot water to the taps at the other end of the building is cool. A standard insulation has been used, would foil backed wool pipe insulation (climatube) greatly improve the heat of the water or should I be looking at a circulation pump?
Is it a combi ? It never ceases to amaze me why anyone would put a boiler that's got to heat the home in the coldest harshest environment in the home the loft , something that I refuse to do for any of my clients there always a better option sometimes you need to be a bit creative, depending on the age of the boiler I suggest it's moved or replaced to the main living space, today it -4 °c and probably no much above freezing in the loft any boiler is going to struggle on hot water delivery most combis can only raise the incoming water temperature by 35°c so say it 2 ° c today then 37° c pretty poor I expect this is what your experiencing ? . Kop
Reply to Cool hot water in the USA area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
I have a 2 pump hot water tank (Flomax 180L fitted in '94) in airing cupboard system with an Ideal classic boiler (downstairs next to an external...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
Hi I recently did some pipe insulating in my loft. The only two I didn't do were the vent pipes. Not sure if that is the right term for them...
