Discuss Direct cylinder thermostat tripping in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there,
Have a direct cylinder feeding a pumped shower and a basin in a bathroom. The existing cylinder was running dry to quickly and it's never been enough to fill a bath properly so installed a 200ltr cylinder along with more stored water in the loft. It's basically exactly the same as before only bigger. Problem is now that the new immersion. (got a new bigger one to fit cylinder an heat all the water) keeps tripping out.
Cylinder has:
- same 22 feed as before
- same Surrey flange ( had to buy 1inch to 1inch quarter bush to fit)
- same power feed.
Direct cylinder is so
Simple!why's it not working?!
Either a loose connection, incorrectly wired or the new immersion is faulty. Get a sparky in to test for you.
Could be faulty MCB - had that problem earlier this year (after having tried by changing immersion element and stat).
Morethan likely a faulty stat, if not it's the overheat.
Reply to Direct cylinder thermostat tripping in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a hot water cylinder which feeds 3 outlets (kitchen sink, basin in bathroom & bathtap) which has never had very good pressure (probably...
1K
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from...
Steveo111
J
Hello, hoping someone can advise me. My boiler stopped working - no hot water or central heating. Called out a company who came and assessed the...
I have just had a new boiler and 210 ltr unvented tank fitted in the loft to replace a very old Baxi back boiler. I have now fitted a Solic 200...
Hi, I’m having issues with cold water to multiple outlets. Taps, showers, toilets cold water is fine at the kitchen sink. The hot water system is...
2K
