Discuss Dishwasher drain pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
The Problem: I put the dishwasher drain pipe into the exit pipe (see pics) and I sometimes get water overflow out of the top of the exit pipe.
The Solution: ???
the drain should be lower than that with a fall on the pipe, 2 your end where you put your hose should be longer be for it hits a bend.
Worth trying just extending the vertical waste pipe as high as you can. Then it has more capacity to receive a higher flow and a higher pressure at the exit. It might lean against the copper pipe though so needs a bracket near its top, or fix against copper pipe in some way.
Reply to Dishwasher drain pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
