Discuss Diverter valve location in the Central Heating Forum area at PlumbersForums.net
How does it switch between water and heating ?
Flow switch and room thermostat via the pcb.How does it switch between water and heating ?
So could the central heating part be broken?There’s no diverter valve it’s a twin pass heat exchanger
Not sure I just drained the water until there was no pressure in the boilerDid you drain the heating system or the taps as there two completely different systems?
Reply to Diverter valve location in the Central Heating Forum area at PlumbersForums.net
