Discuss DIY toilet repair - in need of brownie points from the Mrs.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jimcroisdale
Hi all,
Toilet is leaking when flushed from the toilet to cistern seal and its my job to fix it tomorrow.
I'm a graphic designer.... :-/
I know its probably the big rubber seal (spud?) But I don't know what size will fit. I'll have to take it to bits and then take the old seal to the plumbers merchants and stand at the counter like a Muppet.
I'm on my mobile, but if I've done it right this should be a pic of the loo in question:
And idea what type/size thingy I will need?
Yours in eternal thanks,
Jim
can you take a pic of the underside please as there should be a flush pipe (maybe)
spud? sounds like builder talk!
needs a foam doughnut, if you can dismantle it!!
Pardon our manners Jim, welcome to the forums mate.
spent 3 hours trying to seal one once :(
And did you seal it? Guess it looked good on somebody computer screen in the R&D department. lol
Jim, these have metal brackets that the cistern sits on to take the weight, if you see the brackets under the cistern then warn her indoors that it may not be a 1/2hr job mate.
Reply to DIY toilet repair - in need of brownie points from the Mrs.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
  • Locked
Hi, I have recently been to a customers property who has been having a problem with a leak from a flush pipe. The customer had removed the rubber...
2K
  • Locked
Hi, this is probably a really basic thing, but I'm a complete novice. Have connected a wall hung toilet to a Grohe rapid frame system. I'm...
30K
R
  • Locked
Hi Everyone, I dread needing the toilet because of this problem! The cistern isn't filling up, the water just runs straight through into the...
2K
johnmcginty
J
