Discuss DIY toilet repair - in need of brownie points from the Mrs.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jimcroisdale
Hi all,
Toilet is leaking when flushed from the toilet to cistern seal and its my job to fix it tomorrow.
I'm a graphic designer.... :-/
I know its probably the big rubber seal (spud?) But I don't know what size will fit. I'll have to take it to bits and then take the old seal to the plumbers merchants and stand at the counter like a Muppet.
I'm on my mobile, but if I've done it right this should be a pic of the loo in question:
And idea what type/size thingy I will need?
Yours in eternal thanks,
Jim
can you take a pic of the underside please as there should be a flush pipe (maybe)
spud? sounds like builder talk!
needs a foam doughnut, if you can dismantle it!!
Pardon our manners Jim, welcome to the forums mate.
spent 3 hours trying to seal one once :(
And did you seal it? Guess it looked good on somebody computer screen in the R&D department. lol
Jim, these have metal brackets that the cistern sits on to take the weight, if you see the brackets under the cistern then warn her indoors that it may not be a 1/2hr job mate.
Your ok mate, new donut seal and away you go if it is leaking from the seal, could try tightening the wing nuts first, they don`t have to be tight tight.
Cheers for that! Is it still best to take the old one to the shop abs say, one of those please!
Problem now is so many different sizes and shapes so yes start early and take the old one to the plumbers merchants (not B&Q), expect the new one to look thicker as it`s been compressed for a while. Any name or brand you can see on toilet or cistern?
Nothing on the porcelain, but says WRAS I think, on the top of a plastic bit inside...
wear gloves when you handle the donut otherwise you will get black hands guaranteed
If I'm changing components in a cistern & the donut is obscure I re-use it, clean it up, dry it with blue roll, apply silicone both sides & never get a problem!
Reply to DIY toilet repair - in need of brownie points from the Mrs.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
