Discuss drilling hole in tile cracks my tile! in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
hi all
i need some help and advice
i am tiling around 2 shower pipe fittings. as the measurements were intricate i was practicing on off cuts and trying to create a template. I've noticed when i drill holes into the tiles sometimes they would crack. i don't use any pressure or drill too fast. anyway, the good news is that i have created the template down to the mm. however when creating the template a bit cracked. when i go on to making the holes on the proper tile i don't want that to crack, as i'm running out of tiles. why is it cracking and what can i do to prevent it
method: in this instance, i used my workmate bench and clamped it with G clamps around the tile. i clamped them enough to hold the tile steady, as opposed to over tightening the clamps.
thanks
finest1
Try putting a sponge underneath
I don't think G clamps around a tile to clamp it to the workmate is a good idea. The flatness of the tile and the flatness of the workmate are unlikely to be the same. The place to provide support is directly under where you are cutting, not anywhere else, and you can stop the tile rotating without clamping/bending it!
I usually put a bit of foam wedi board under the tile to absorb vibrations. But even a towel will do.
As others have said, no clamping. Could clamp a bit of 2x1 wood to the work bench to butt the tile against to stop movement.
Angle grinder bits/holesaws are vastly superior to drill ones. They allow the angle grinder closer to the tile, so you have more control. They also spin twice as fast as a drill.
I’ve got a nice 30ish mm one I use for shower outlets. Bit pricey tho for a one off, around £40.
Try the shd ones mate around 15 off Amazon same quality as the rubi ones
Reply to drilling hole in tile cracks my tile! in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I have a Column radiator to fit to a porcelain tiled bathroom wall. The wall is breeze block covered (by solid bed of tile adhesive) with 12mm...
5K
Hi all, Slight hiccup on a job. A tile cracked when I was replacing a like-for-like bathroom towel rad. (Not a usual occurrence for me, as I'm...
7K
  • Locked
Here they are! Totally refreshed for this year. We have given a makeover to all of the BOXSET range. All options are now presented in smart...
2K
365drills
  • Locked
Brand new for April 2016. Launch of boxsets for drilling holes into very hard porcelain tiles. Two sets have been revamped. The third is...
365drills
