Discuss electric freezer & pool water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
BLOD
Does anyone know the freezing point of chlorinated water used in a swimming pool ?
Trying to decide whether to take a job on that will require 25mm mdpe carrying pool water to be frozenand and not sure if the chlorine lowers the freezing temp too much for it to work.
Mdpe will take too much to freeze.............squeeze off will be the best bet
thanks gents - good advice ! squeeze off worked a treat :hurray:
Reply to electric freezer & pool water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Short version: Do frost protection valves trigger when the water in the pipe gets to threshold, or when the air temp drops? Long version...
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to...
Hello all, So been having somewhat of a time with my Aqualisa Quartz 9.5 electric shower. A few.month ago I put up with a few problems it was...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Hi! Our main stopcock is weeping. I phoned the water company, first-person thought it was their problem as it was on the 'outside' of the water...
