Discuss Finding a small leak on UFH in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
mutley racers
Subscribed
Hi all.
Got a leak on an underfloor heating system 2hich is dropping 2 bar of pressure in 2 1/2 weeks. Would one of those infrared flir phone attachment cameras work at all?
Thanks all
I could actually purchase one and if I don't like it send it back. But as the leak is so small I am not sure it would find it
Depends on quality of the camera and I can’t advise on that I’m afraid. But our dedicated unit at work is pretty accurate.
I’ve also in the past, pumped systems up with an air compressor and used a stethoscope.
Air compressor is interesting thought.
What unit do you use at work?
Thanks for replying.
If you’re gonna pump air, make sure boiler/sensitive equipment is isolated and get it up to 4-5 bar. You can hear the hissing with a stethoscope.
We’ve got an older Testo heat gun, I bet the newer ones are even better.
Is it all ufh ?
Reply to Finding a small leak on UFH in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
What the easiest way to find why my boiler is losing pressure. It is about 5 years old Vaillant combi boiler, we have just had 2 vertical radiator...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
Hi all not a plumber but am an engineer I have pressure drop in the system Worcester Bosch came back after repressureising the expansion vessel...
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also...
Hi all. I've currently got a system boiler with cylinder and rads on s-plan. I'm planning on installing UFH in my kitchen/diner and...
