Discuss Fire cement recommendations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've tried most, is there anything out there that's just a little more elastic and can handle thermal expansion.
So is that one . But u do get higher .
Solid flue of multifuel stove.
You think HT silicone would survive(Optimum op temp 150 - 250 deg C)?
Gives me an idea though, use a mix HT silicone with fire cement.
stick with the fire cement, been fine for the last 50 years or so.
No don't use heat resist silicone. I find it won't even last on standard efficiency oil boiler flues near the boiler- it just falls to bits eventually.
There are better quality fire cements, but not sure what they are. Most seem to crack eventually. It might be possible to add fine mica well mixed into the fire cement.
It is just one of those things to be redone every year or two on the wider joints, like at top of stove. Give the area a soak with water before you apply the fire cement, as that makes it last longer.
Have you tried ready made stuff from screwfix. Cheap as chips. Easy to apply. Never had a problem with it but i havent managed to raise the temp of the houses ive worked in to 300 degrees yet [emoji12]
Thanks for replies.
Yes usually use that and leave to dry for a week before lighting anything.
This stove flue is rear entry (rather than straight out the top) so I have more joints than usual and as Best says it's something I usually have to redo every couple of years or so because it always cracks eventually but I'd rather not.
Might try adding some lime to the fire cement, it may have the same effect as it does to cement render.
Thanks for replies.
lime and sand gives a soft porous mortar, not what you want with a flue joint really, dont think the manufacturers would support you when the lounge contents dont wake up!
Vitcas range. I used outdoor oven cement which was left over. Didnt swell, crack and good to 1250c I think. Ready mix powder so mix as you need it, no more gone off pots of fire cement in van. I'm going to try others in range to test.
Reply to Fire cement recommendations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
