Discuss fitting shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Davy
Hi, im about to replace a shower tray, the existing tray stands on legs and the waste pipe lies between the tray and floor. i want to fit a stone tray straight onto floor with the trap and waste pipe obviously under the floor. this would mean that the waste pipe would be lower and thus be on a slight incline away from the tray. would the water still flow away? thanks for any assistance.
the waste should have a fall away from the tray, water will find its own level and if there is an incline then you may find the water stays in the tray or the water will stay in the pipe and could cause blockages due to the lack of flow
also check the waste and your joists as you can't go notching 40mm notchs out of joists where you want.
that maybe the reason why the original tray was on feet.
Reply to fitting shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning...
Hi, As per title we have a regular smell from the shower trap. Clean the trap twice a week, had a cleaning rod down the shower waste pipe and no...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built...
Hi, came across this old push fit waste pipe. Stripped out the old shower and it was a 40mm waste pipe siliconed in the fitting. The fittings at...
Hi Everyone, Can anyone help? I have been searching but with no luck. I am trying to fit a Duravit shower trap which has a 50mm outside...
1K
