Discuss Fittings OR Suggested Configurationn Cistern in France in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
kc53ffs
Looking to connect a T piece to a Cistern feed in France The feed to cistern is (nut size) 18mm to 21mm water valve and with a 23 mm mains in supply
I need a configuration I assume with a T to connect 23mm out
As an example 18mm to 18mm Cistern to valve Tap with 23mm out is what I was thinking
Can anyone help suggest please
kenny
Reply to Fittings OR Suggested Configurationn Cistern in France in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
