Discuss fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mainly end feed compression if water logged but not in sight were possible
gotta be endfeed. compression if can't solder in awkward spots or pipes wet,
pushfit if its nearly teatime ....shhhhh!:p:p
End feed mainly but what ever is suitable /passable for the job in hand.I find end feed looks the neatest.:)regards turnpin
End feed, compression if wet and yorkshire if I don't have a spare hand.
Reply to fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'm considering fitting an isolator valve to 15mm feed to my toliet cistern. It would require cutting off an existing compression fitting...
A
Hi guys I finished my gas course in September can anyone help me i need to do 2 install and services. Am living i ln leeds west yorkshire I do...
Ahmad marian
A
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of...
Hi have surplus water feed and return pipes in my home. I can't isolate them so will need to freeze. House built 1970's. They're as far as can...
