Discuss Flexis to pipe up bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Especially the pushfit ones
I find the rubber seal a real help with bath taps. If a tap connecter with a fibre washer isn't absolutely spot on it will squirt out.
Wipe Jet Blue Plus onto the fibre washer, as long as you don't cross thread it it won't leak.
insurers in Oz are going against flexis fm what I hear fm family over there, seems that the flood damage to my sisters place only just got paid out by insurers, she now has a note on her insurance docs stating damage due to flexi fittings is not covered! we will go the same way idc once they see the damage they can do when they fail
What would cause one to fail?
Better not leave that filling loop connected then!!
Fairplay, that's the biggest load of tosh i've read on here for a while. Having a superiority complex over your non-use of flexible hoses is borderline madness.If you are a plumber you will pipe it up, if you are not you will use a flexi, it's no excuse to say its difficult to pipe up, that's what separates the plumbers from the rest
it's very easy to hard pipe then drop the bath in then connect it up, flexis are not required
of course kirk meant to say if your a proper plumber you would have done them in lead personally i can do either depends on what the jobs paying but i still dont fit flexis to single taps as they will come loose in the basin,sink bath whateverIf you are a plumber you will pipe it up, if you are not you will use a flexi, it's no excuse to say its difficult to pipe up, that's what separates the plumbers from the rest, ok most of the baths I've done are standard, but I've done many 100's, not sure if I've done 1000's, but I've done enough to know how to do it, and most of them were done before flexis were available, but even on the fancy baths with taps in the middle of the back wall it's very easy to hard pipe then drop the bath in then connect it up, flexis are not required
There is nothing wrong with using flexible hoses on bath taps.
This is an attitude that I really, really don't like. Yeah, great, you can plumb a bath in using copper but when it comes to replacing the taps or fixing a leak, what then? Yes, that's right, you have to remove the bath and the tiling around it.
This attitude is all about ego and not about doing the best job you can. There is no excuse for plumbing something in that is then nigh on impossible to work on without uninstalling it first. I see no difference to this and the people who see nothing wrong with installing concealed showers with no thought to future repairs or replacement.
I know this is not an opinion shared by many but it really gets to me. As far as I'm concerned part of being a professional plumber is not just trying to make sure you install baths, showers etc. to work perfectly but to also ensure they can be worked on in the future, too.
Use the correct tool for the job.
If that is the case every house built over the past 10 years wont be covered in Western Australia,cannot do as much damage as overhere the majority of builds there are one storey,concrete slab and the bathrooms have a tiled floor with a floor gulley fitted,Aus plumbers wont go back to the dark days of brazing under basin cabinets
funny thing I note is that they dont teach anyone how to pipe up baths and basins at college using flexis, must be a reason for that!
$48000 worth of damage fm 1 flexi....................
Reply to Flexis to pipe up bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
