Discuss Flue termination with vented eaves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
Bhoydavid
Was at a service today and noticed when checking the flue out side it terminated under the eaves ( in the corner of an L shape on the building so eaves on the building either side of it were above the flue). When working the poc's were going up and hitting off the vented eaves but not going in the vents, they appeared to waft from under and up onto the roof. Wasn't really sure about this as I thought it could be classed as poc's re-entering the building. Anyway got a second opinion and the gaffer was OK with it and said as long as the flue termination was within regulation distances it was fine.
Thoughts on this? His name last to it anyway but was he right?
Was it more than 200mm below eaves
Your gaffer is right if its more than 200mm from eaves and there are no air vents in eaves , sofits then this would be classed as pocs re-entering, if vents were there it would need extended out past and clipped,
25mm from eaves
never finished last thread 25mm if it waz extended out past which by sounds it wasnt, but the 200mm is from eaves , not vented eaves
Its always hard to judge without seeing it, but from your description I would be a little concerned of POC's entering the building. Just because the clearances are fine, it doesn't mean its going to be ok.
I would check with the manufacturer, Worcester state 300mm below an opening for the jnr for example.
300mm from a vented eaves. and flue cant be extended out the measurement is from where the flue exits the wall not the end .
this is not acceptable .
Reply to Flue termination with vented eaves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My installation has been classed as Dangerous 'Do not use' by my boiler manufacturer. I have an Ideal Logic 30kw Combi boiler mounted as high as...
E
Hi all, Apologies if this has been covered elsewhere but I can't find an answer to my questions. I have a back boiler and gas fire which h has...
I live on the 3rd floor of a 6-story block of flats. (26 flats in total). During the evening when all people are inside their flats and using...
Morning all, as always can never find an exact existing thread / discussion where I don't feel like I'm making one too many assumptions. Can I...
5K
