Discuss Flush valve replacement. What make is this? in the USA area at PlumbersForums.net
Hi everyone. Being driven mad by a leaking toilet. 2 in fact!! It’s not the fill valve over filling to the overflow so assume it’s the flush valve.
Anyone know what make this is? The fill valve says WDI so guess the flush might be the same? If it is, is there a compatible valve I can fit in the basket?
Reply to Flush valve replacement. What make is this? in the USA area at PlumbersForums.net
Hi
Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi all
Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
