Discuss Flush valve replacement. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone recognise this flush valve? It's broken and tends to let water pass ...
Looks very cheap and nasty. I have replaced relatively similar-looking mechanisms because they were not working. You don't have to stick with the same make and model flush valve, you know.
Reply to Flush valve replacement. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
I have a green star ten yrs old keeps increasing pressure, feel on off filling valve not working, drain off to recommended, but after few days it's increased whilst cold...is this a regular problem.
