Discuss Foam shower trays in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Be careful ermintrude, using some kinds of silicones and no nails etc dissolves the bond between the cement layer and foam on a foam type wet room former.Used a wet room former screwed and silicone
Thanks could even use my floor tiling trowel to do thisyeah like chalked says make it fairly wet , but if you put a thick bed of muck you could make grooves in the muck with the trowel, kinda like what a tiling trowel does lay the tray on top and shimmy it down to even out the muck, if the bottom of the tray is porous might be worth unibonding it
Reply to Foam shower trays in the Plumbing Jobs | The Job-board area at PlumbersForums.net
